97 chevy 4l60e 1st and reverse grabbing
Old 08-12-2006, 10:17 PM
brybe's Avatar
Default 97 chevy 4l60e 1st and reverse grabbing
I rebuilt this transmission last year (broken reaction shell) , new seals, new frictions and plates. When taking off its like it is stuck in two gears and is grabbing until it shifts into second gear. From second on up its fine. It does this in reverse also. Already checked fluid and removed the pan, there were some fine particals (almost sludge like) on the magnet nothing abnormal. The filter was clean and i was able to blow air through it. Any quick checks and or ideas are appreciated.
Old 08-13-2006, 04:01 AM
rocketz28's Avatar
check the vss might be going out
Old 08-28-2006, 10:37 PM
brybe's Avatar
Disassembled transmission and found ¾ clutch friction paper separated from plates.
Also should note the clutches were not burnt, just looks like the paper wasn't glued well. These were the heavy duty Alto clutches. Any suggestions on what brand to put back?
Old 08-29-2006, 11:31 PM
LS1Tech Sponsor
performabuilt's Avatar
I like raybestos , but the binding would not liley be caused by the material coming off but rather its the result , check the low roller clutch and input sprag , which clutch set had the friction material separated
performabuilt
Old 08-30-2006, 07:53 AM
brybe's Avatar
I checked the lo roller and the input sprag both are locking up in one direction. The 3-4 clutch disks were the ones seperated. I have disassimbled the valve body looking for clutch material, and checked the 1-2, 2-3 solienoids so far have not found anything. Think I should install a new converter also?
And thank you for the thoughts.
Quick Reply: 97 chevy 4l60e 1st and reverse grabbing
