Anyone in here running a Th350 or th400 as daily driver
Old 08-15-2006, 12:28 PM
ncd1966's Avatar
Default Anyone in here running a Th350 or th400 as daily driver
if so post up and put what convertor you have
i am thinking of going this route
Old 08-15-2006, 12:54 PM
11SECDWS6's Avatar
Mines not really a daily driver, but I've got a Fuddle 3600. I'm not sold on this converter to be honest, so next time I'm probably going with a Yank.
Its very drivable though, it just feels alittle too loose on top than what I was expecting.
If you do alot of cruising at highway speeds your gonna miss not having od...
Old 08-16-2006, 07:35 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Will a TH350 converter bolt to the LS1 flexplate? And do you have to run a kickdown cable?
Sorry to jack your thread but I am getting ready to do the swap myself.
Old 08-16-2006, 12:26 PM
ncd1966's Avatar
i am thinking about using a trans king 4000 in my Trans am with the th350
and just buy toyota for a DD
Old 08-16-2006, 03:29 PM
11SECDWS6's Avatar
That is who I bought my TH400 from. Good customer service.
Old 08-17-2006, 08:35 AM
Jimmy P's Avatar
I basically daily drive mine in the summer. ATI 3200 stall with a reverse manual TH400.
Old 08-17-2006, 09:51 PM
Out1aw's Avatar
what kind of gas mileage are ya'll getting out of these cars in the city with that tranny? also what gear set?
Old 08-18-2006, 07:14 PM
1QWIKZ's Avatar
th-350 here with a 4000 stall/3.42 gears
Old 08-18-2006, 07:54 PM
WhiteStripes's Avatar
Good Idea.
Old 08-18-2006, 08:51 PM
Z28/2002's Avatar
What other mods are done to your car?
Old 08-18-2006, 09:47 PM
Full-Force's Avatar
I have a TH-350 with 3500 stall and 4.10 gears. I have a full manual valve body in mine. Put it like this. I try to stay at 50mph or less. Im having my converter restalled to about 4200.
Old 08-19-2006, 12:25 AM
revtime's Avatar
I agree, I run a TH400 with 3.73 gears and a 26 inch tall tire.
I cruise at 60 mph on the hiway so the tach stays about 3000 RPM.
Daily driving it would not be a problem if you did not have a long commute.
Old 08-19-2006, 11:37 AM
SUX2BU's Avatar
i daily drive mine. TH350, RMVB, non lock up 5300 8" stall, 4.10 gears.
I used to drive 90 mile round trip a day. But now i moved closer to my job.
Old 08-19-2006, 12:54 PM
Honda Hunter's Avatar
I'm thinking about doing this as well.
Old 08-19-2006, 04:19 PM
SSilverSSurfer's Avatar
what did it run you? i was thinkin about doing a Rossler cause ive heard good thingsabout them
Old 08-20-2006, 03:29 PM
gd1996's Avatar
People did it for years before they came out with od transmissions. Hurts gas mileage some of course, but if your after gas mileage then get a hybrid or something
Old 08-21-2006, 02:57 PM
schmidt69's Avatar
heres what i run in my daily driver
*Driveline is built like the govenor of California
Built TH400
Vig 3600 non/lock
TCI Flex plate
Reverse Manual valve body
Trans Brake
B/M shifter
Old 08-21-2006, 11:12 PM
revtime's Avatar
Built TH400
Vig 3600 non/lock
TCI Flex plate
Trans Brake
B/M shifter
Mine is just a bit different. Damn close though.
Rossler TH400
Coan 4000 non lock
B&M Flexplate
Reverse manual valve body
Trans brake
B&M shifter.
Quick Reply: Anyone in here running a Th350 or th400 as daily driver
