what mph lockup is recommended?
I am going to bump mine up a bit, it's too much and causes the RPM's to drop too low when it locks at 38mph (stock setting). I am going to bump it to 44-46mph range. At least in 4th gear. I will have 3rd locking at 30 as it does when you use "3".
I moved both 3rd ad 4th gear lockup. just experiment a little till it's at your liking. Also moving your part throttle shift points help alot with cruising around town, especially with big cams.
Dan
Dan
