converter swap
converter swap
i want to swap converters in my 01 ss does anyone know if the 4l60e has bolts at the top of the trans to unbolt it from the engine if it does i dont know how id get to them!!
take loose the torque arm and other parts in the way. put a jack under the pan and remove the cross member. then lower the jack to where the transmission is tilted down all the way. should be able to reach the top bolts of the transmission bellhousing to engine wit ha long extension. Don't forget to remove the 3 flexplate to converter bolts.
