Yank SS3600
Old 08-26-2006, 09:22 PM
losiguy's Avatar
Default Yank SS3600
I talked to Yank and they reccomended this converter to me. Will this converter work ok for DD? They said since I have 3.73 gears it should work very well with the 2.5str to drive more stock like. And does this converter have the balooning plate for nitrous? Thanks.
Old 08-26-2006, 09:23 PM
BlackHawk T/A's Avatar
No balooning plate, good choice for the street.
Those tires won't be enough to handle the 3.73's with that converter, but you'll find that out soon enough.
Old 08-26-2006, 09:37 PM
losiguy's Avatar
Will the converter still work with the nitrous? Ive heard you have to have that plate if you have nitrous or your wasting your time.
Also is there a better converter that will be alittle more easy on the tires? I love the Nitto's, I daily drive them so I need a tire that can last longer then 4k miles like MT's.
Old 08-26-2006, 09:55 PM
distortion_69's Avatar
Should work good with a fair sized shot. They are relatively tight.. but I wouldn't expect mindboggling results with a big hit..
Peace,
Josh
Old 08-26-2006, 11:07 PM
slimcracka's Avatar
the ss series is based on a power adder (NX) type car
the pt is more based on more of an NA car..
Old 08-27-2006, 12:55 AM
Don't think so, the SS is based on a mostly stock NA street driven car setup. Hence, "Super Stock".
While we are on the subject though, what does an anti-ballooning plate get you?
Old 08-27-2006, 07:11 AM
01Z0H6's Avatar
I too spoke with Mke @ Yank... I have had my Yank SY 3500 for about 5 years now and i DD my car.. I really like the low STR "1.68" coupled with my 323's... They don't make the SY3500 anymore.. I too am considering the SS3600 for my new Rock on Level 4...
My car however is nowhere near stock.. I am running a 232/236 .595 .601, LS6 Ported heads,FAST 90/90,Trueduals,pulley,long tubes.etc....
Mike told me this converter would work well with my set up for daily driving.
$725.00 shipped to my door.
Old 08-27-2006, 09:39 AM
Well I should probably add that its also made to feel closer to stock than some of the more "race" oriented converters but it can have a wide range of uses also. I will probably change mine in the future to something with a lower STR when I have a different gear in the rear and/or a built engine. But for now its perfect.
Old 08-27-2006, 10:01 AM
Gun5's Avatar
i wish i had gone with a littler stall
Old 08-27-2006, 02:04 PM
Gregg1LE's Avatar
Littler as in lower RPM's or physical size?
Old 08-27-2006, 04:06 PM
Gun5's Avatar
rpm';s
