What else do I need?
Well I've decided to go with about a 3500 stall and Im going with a TR230 cam in the near future. Question is, will I need to upgrade nething else in the car other than just a trans cooler?
You should get a shift kit. It firms up the shifts by adding line pressure so that when you mash it at ~35mph and your car jumps down into first gear and right into your powerband your transmission does not slip, therefore does not cause friction and heat build up in the transmission. A shift kit should in fact pro-long the life of your transmission.
