It ONLY shifts DOWN!!!!
here are my test results:
With the engine off:
From Park I can move the shifter all the way to 1st and the gear selector lever on the tranny actually goes to 1st.
If the gear selector on the tranny is in 1st (and so is my shifter) I try to move it to park, the tranny will stay in 1st.
Is the shifter pushrod bent or something???
In a nutshell: It will only shift from Park -> Neutral -> OD -> 3 -> 2 -> 1st
but it wont do the opposite!
Moderator
Get underneath it, find the snap-clip adjuster, pull the
cable snug and snap it into place. I think the cable is
pulling one way, but you can't push on a rope (with the
jacket free to slide).
I really dont think it will ever get out of 1st. EVEN if I get under there and manually shift the shift lever!
I think I damaged it when pulling/installing the engine
My friend had this problem.. he just bought a new one
