Big Difference going from 3800 stall to 4000?
Old 09-08-2006, 08:59 PM
Dan
Dan's Avatar
Default Big Difference going from 3800 stall to 4000?
Car is my daily driver, Mods are in the sig..Thanks
Old 09-09-2006, 12:33 AM
02 BLK WS6's Avatar
Depends on converter.... If they are the same brand and set up you shouldn't see much difference..... Example loose 3800 to a tight 4000. The 4000 would have more drivability, especially for a DD. If you are looking for a tight 4000, I have heard nothing but praise about Yank being tight. Vigilante is on the same level but a little looser than Yank.
Old 09-09-2006, 10:15 AM
BlackHawk T/A's Avatar
Yank told me that the difference between the SS3600 and SS3800 (200rpm stall speed) would turn into a difference of a 400rpm shift extension. Make sure you are considering that also.
Old 09-09-2006, 12:13 PM
Dan
Dan's Avatar
Thanks for the info..I want to go from a vigilante 3800 to a Yank 4000..My car is already tuned with the vig 3800, I hope it doesn't screw up everything & not shift for me at WOT
Old 09-09-2006, 01:17 PM
Your new converter will likely stall lower and feel tighter than the old one. Is that what you wanted?
Old 09-09-2006, 01:26 PM
Dan
Dan's Avatar
I don't want it to stall lower, A little tighter would be good..I have always read that the Vig's stall higher than advertised..weird thing is I went from the old school ST3500 yank to a Vig 3800 & they felt exactly the same..I really want to go back to yank but don't want to go to high of a stall for my application..Don't know if I want to go over 4000 on a daily driver, but I do want to try to squeeze a little more et out of it as I do drag race about once a month..I was dead hooking on my current setup to get that 12.21..
Old 09-09-2006, 03:21 PM
Yank SS4000 sounds like the ticket for you. Have you checked your stall speed with the Vig 3800? I was just assuming it would stall over the 4000 that your new one would be doing.
Old 09-09-2006, 03:25 PM
Dan
Dan's Avatar
Thanks for all the info Blackhawk..Not sure how to check the stall of a converter? I decided 5 mintues ago to get the SS4000 Yank Thanks again..
Old 09-09-2006, 04:13 PM
Frost's Avatar
Personally it sounds like that money would be much better spent somewhere else...
Old 09-09-2006, 04:16 PM
Dan
Dan's Avatar
I need a converter no matter what..Trans took a dump. I don't want to wait to send the converter to vigilante to "freshen Up"..I can get up & running & then send the converter back & have it for a spare or sell it...
Old 09-10-2006, 03:02 PM
kickassT/A's Avatar
i just switched to a yank py4000e from a vig 3600, and i can't tell the difference around town. at wot the vig flashed higher. shift extention might be a tad lower with the yank too. i think if i hadan't torn the lockup clutch out of my vig i would still have it. we'll see if i change my mind when i spray it.
