line pressure band-aid
My tranny is sliping when I am cruising at 60 then I try to pass it begins to slip not all the time but for sur after I drive a while. Can I increase the line pressure with hypercrap? will this help it last alittle longer?
LS1Tech Sponsor
Its very likley you have a bad pcs (preasure control solinoid). if this is the case no type of external ajustability will help , I suggest you service the transmissions , replace the pcs while your in there and do it soon if anything will help this will ,
PerformaBuilt
PerformaBuilt
LS1Tech Sponsor
Its pretty simple , remove pan . you will see a semi round aluminum cover at rear area of valve body , remove the three 10mm bolts lower accumulator , remove the 8mm bolt holding the solinod bracket , remove the bracket and remove the solinod slide the new one in and put everything back .
its that easy
performabuilt
its that easy
performabuilt
