Stall noise?
Old 09-18-2006, 10:42 AM
LV2XLR8's Avatar
Default Stall noise?
I just recently installed a TCI 3500 stall with a Perma Tranny Cooler in my car and I noticed a slight whine in the transmission. Is this normal?
Old 09-18-2006, 04:37 PM
LV2XLR8's Avatar
It only whines at 2000+ 1st through 3rd when gotten on it a little bit... Once it unloads into 4th there is no more whine... No whine at idle or regular acceleration under 2000.
Old 09-18-2006, 04:44 PM
94z28L's Avatar
are you 100% sure its the trans and not the rear?
Old 09-18-2006, 06:34 PM
LV2XLR8's Avatar
yes...
Old 09-18-2006, 06:52 PM
94z28L's Avatar
k well that eliminates that possibility, kinda a dumb question but is it completely full of fluid? converter all the way on the input?
Old 09-19-2006, 09:02 PM
LV2XLR8's Avatar
Yes and yes.
Old 09-20-2006, 05:00 AM
BlackHawk T/A's Avatar
And it didn't do this before? These cars do have a slight whine but if you have a loud exhaust you can't hear it.
Old 11-05-2006, 08:41 PM
LV2XLR8's Avatar
I think it's the transmission pump. Ever heard of this problem?
Old 11-05-2006, 08:54 PM
LS1Tech Sponsor
performabuilt's Avatar
Hi since it stops in fourth I doubt its the pump , but since you added a cooler that is where i would look make sure there is fluild flowing through it ,the whine could be planets starving
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-05-2006, 09:36 PM
FLT
FLT's Avatar
I can't see how it could be planets when in third gear everything is turning 1:1.
LV2XLR8- I believe that this bearing noise that is making noise when loaded. It could be a bearing in the tc or in the trans however you said that it happened after the tc swap so I think that is where to look first. Vince
Old 11-06-2006, 12:00 AM
LS1Tech Sponsor
good point on third gear everything is turning as a unit.my brain was thinking 4th wrong !
__________________
Call 888-744-6542
Old 11-06-2006, 08:52 PM
Retired Street Racer
Matt D's Avatar
Vince is the man. I trust him, and only him, when it comes to my transmissions
Old 11-07-2006, 06:22 PM
LV2XLR8's Avatar
How serious of a problem is this? I do not have access to a lift to check it out. Thanks guys for all of your help!
Old 11-07-2006, 07:07 PM
fastSS2002's Avatar
I have had the same problem since my fuddle was installed.I was told it was gear whine,but i took that with a grain of salt.
ttt
Old 11-09-2006, 03:17 PM
LV2XLR8's Avatar
ttt
It's definitely coming from the tranmission...
