Dropped the Trans Pan....
Old 09-24-2006, 02:48 PM
VenomInside's Avatar
Default Dropped the Trans Pan....
Here are some pics of if. The magnet seemed clean (as far as no actual metal shavings or anything) but when we moved our finger on the bottom of the pan this is what we found (look normal?) (pic 1). Trans fluid seemed fine in color and everything. There were some dark patch's but nothing too out of the ordinary. So what you guys think. Everything look/sound ok?
Old 09-24-2006, 03:24 PM
99SSragtop's Avatar
Normal
Old 09-24-2006, 03:25 PM
K just making sure cause my TC took a ****.
Old 09-24-2006, 09:52 PM
Chris18927's Avatar
thats just realy fine metal shavings
Old 09-24-2006, 11:12 PM
Gregg1LE's Avatar
I put on a B & M deep tranny pan this weekend and had a little of the gray gunk but not as much as you had
Old 09-24-2006, 11:37 PM
SDB
SDB's Avatar
looks mostly normal...I would drop te pan again in a few weeks and check again. that stuff is probably just real fine metal shaving and such. Wouldn't hurt to check it again.
SDB
Old 09-25-2006, 05:55 AM
Thats what i want to get cause its got a drain plug as well
SDB
10-4. Thanks!
Old 09-25-2006, 06:29 AM
s346k's Avatar
normal.
Old 09-25-2006, 08:07 AM
01Z28M6's Avatar
How many miles on the car and if you know, how many miles since a fluid / filter change or flush? What you show is about what I had on my 100k A4.
Old 09-25-2006, 09:22 AM
s346k's Avatar
my 45k a4 had much more than what i see in his pictures. my rear dif was even worse.
Old 09-25-2006, 01:38 PM
craparo's Avatar
That is normal, even when I am working on the 4l80's with 30..40+ thousand miles of normal/hard driving. Just clean the pan out good, change filter and fluid and you should be fine. Aslong as you don't see actual shavings or hard pieces.
Old 09-26-2006, 02:40 PM
SoCalZ28's Avatar
normal, mine looked the same when i opened her up after 47k
Old 09-26-2006, 11:40 PM
Well not sure what the fluid/filter had on it but i bought the car with 41K on it and its at 51K.
