A couple TH350 questions
I have a TH 350 in the Z (bought this way) and have a couple questions
1. Speedo doesn't work, someone told me you could fix it for free using the ABS sensor, is this true and if so details
2. It has a 3500 stall, what RPM should it be able to flash to off the line.
Any help would be greatly appreciated
Kris
Kris
not sure on the stall part, but here is for the free speedo.... https://ls1tech.com/forums/automatic-transmission/479729-free-way-get-speedo-work-th350-th400.html your abs won't work after this mod.
