Vaccum Mod In A 4l60e
Old 10-05-2006, 09:04 PM
dnkynrbk's Avatar
Default Vaccum Mod In A 4l60e
Is this worth the extra money and what do you hook the vaccum hose up too. thanks guys
Old 10-05-2006, 09:40 PM
ratxtreme's Avatar
I like it on my truck. I hooked it up to the brake booster.
Old 10-05-2006, 10:03 PM
FLT
FLT's Avatar
It is worth it in my book! I do build them both with the mod and the epc. I do prefer the vac mod setup but that's just my 2cents!
Old 10-05-2006, 10:38 PM
LS1Tech Sponsor
performabuilt's Avatar
we prefer to keep the pcs , The overall shift adaptability is much better ,
www.performabuilttransmissions.com
Old 10-06-2006, 02:33 AM
PBA
PBA's Avatar
"The overall shift adaptability is much better with the pcs"
How?
Old 10-06-2006, 05:04 AM
BlackHawk T/A's Avatar
Start here.
https://ls1tech.com/forums/showthrea...ght=vacuum+mod
Old 10-06-2006, 07:42 AM
LS1Tech Sponsor
The pcm lowers and raises line preasure for more reasons than just throttle position , It monitors temperature , converter slip % and shift error times and ajust preasure acordingly ,A vacume modulaor defeats its ability to do that ,
Old 10-06-2006, 08:59 AM
Custm2500's #1 Fan
silver-mod-o's Avatar
I love the vac mod in my FLT tranny... its tame as hell just cruising around, and nice and crisp when I need it to be... I wont own another tranny WITHOUT IT!!!
Old 10-06-2006, 09:16 AM
LS1Tech Sponsor
Dont get me wrong they work fine , I just prefer the pcs ,
Old 10-06-2006, 11:10 AM
Camaro ChriSS's Avatar
That of course makes sense - but has the problem been for most people a lack of ability to know how to make adjustments through tuning for the pcm control, and the vac mod has just made that job easier (by bypassing the pcm control of line pressure)? Not many (including me) really know how the pcm really affects the line pressure well enough that they can achieve the same results through tuning as they can with the vac mod.
Old 10-06-2006, 01:54 PM
LS1Tech Sponsor
I can understand the programing issue As for how it works it pretty simple really , its and electronic valve that vents presure by cycling on and off and varying speeds.
But I can definatley understand why that might be a difficult setting to make in programing , So what we do is turn the torx screw in the center 1/4 turn clockwise , which basically shortens the open time by applying more force to the return this causes and across the board 4-6 psi increase , Yet the pcm is not the wiser so it continues with normal control as if there has been no change this works well increases all apply presures and even lockup is improved with no fear of solinoid flooding which can happen when you raise the presure by other means ,
