building a 5.3L need to pick a transmission
well i have decided- im gonna get this thing dyno'd for 9psi but then i will be picking up a 5.3L out of a 99 or 2000 silverado putting LS6 heads on it, Boost friendly/mild cam shaft, Diamond low c/r pistons, total seal rings, eagle rods, scat crank, and a 76mm turbo and see what she can do- gonna take lots of work- GOAL HP= 700whp
im going to be going on the hot rod power tour so i need an OD for cruising
what all do i need to make a 4l80e hold 700whp consistantly?
shift kit, servos, torque converter, tranny cooler, tuning?
LS1Tech Sponsor
700 hp eh ok two choices in the links below best customer service period
check our offerings out at www.performabuilttransmissions.com look at the PRO RACE FOR LS1 AND THE ININCIBLE
thanks
thanks
