guys with th400 in ls1, exposed converter/flexplate!?
Old 10-08-2006, 02:23 PM
sleeperstyle's Avatar
Default guys with th400 in ls1, exposed converter/flexplate!?
if you have the swap done you'll know what i mean, the whole bottum of the converter/flexplate is exposed to the elements. do they make a cover or can you modify some sort of cover that came with the th400? im sure it would be fine leaving it exposed but i'd rather have some sort of cover on there in case i get caught in the rain/ whatever.
Old 10-09-2006, 08:18 AM
Kevin Winstead's Avatar
Sleeperstyle,
TCI sells a plastic dust cover for the TH400/TH350. It's part number 743866. It's around $25 directly from TCI.
Kevin
Old 10-09-2006, 09:57 AM
12secSS's Avatar
The 1500HD trucks came equipped with a 4L80E (similar to a TH400), they use a cast cover. You should be able to score one from GM very easily, that is what I plan to do.
Quick Reply: guys with th400 in ls1, exposed converter/flexplate!?
