neutral safety switch wiring
Anyone know the color codes of the wires for the neutral safety switch and backup lights on the stock shifter. I'm trying to wire up a new shifter and can't find any of the color codes on here.
thanks,
Bobby
thanks,
Bobby
Are you installing an aftermarket shifter? This should help if so (taken from the TH400 FAQ sticky up on top) :
Hope this helps you out.
Originally Posted by 12secSS
... OEM park/neutral safety wires (connect together purple and dark green) and the reverse wires (connect together brown and light green)...
yes, I'm installing an aftermarket shift. that does help. I could only find 6spd to a4 harness stuff when I did the search. maybe I just didn't look through it close enough.
thanks again.
thanks again.
