A4 wont shift fast when N2O is on, HELP
Damn trans wont shift on time when nitrous is on, It goes normal, but when nitrous goes in it gets crazy, like it stays in 6 to 6500k rpm for like 2 or 3 seconds and then shifts, so it sux and my numbres at the track are never accurate because of that. Im done I need something to fix it ASAP, or wich trans to get if the car will stay more for the track than street.
Thanx and help please
you can fix that with a tune, they can lower the shift points a little. mine does that. i have noticed if i set the window switch off at 5800 and leave the trans in third it doesn't do it as much. before my tune on the 2-3 shift the car would bounce of the limiter 3-4 times before shifting.
You need to tune your car to shift a couple hundred rpms before you want it to shift when spraying. You also need have your window switch pilled to shut off at least 200 rpms before your shift and come back on about 100 rpms higher afterwards so it can fully shift before the kit licks back in. Thats what I had to do with mine.
