New Converters Are Available Now See Inside
Old 10-12-2006, 10:59 PM
LS1Tech Sponsor
performabuilt's Avatar
Default New Converters Are Available Now See Inside 3000 to 5500
http://performabuiltautomatics.com/converters.html
sorry if made any duplicate post they arent showing as posted after i click
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 10-13-2006, 09:44 AM
Greaseymec's Avatar
You have a PM.
Mec
Old 10-13-2006, 09:56 AM
BAIN's Avatar
How efficient are these converters? It seems that the higher stall you get in a 4l60e converter the more inefficient they get. I would love to get a 5500 that would be efficient up top like the ATI 5500 ones the guys run in the TH350/TH400's. Presently I have a 4800 and it looses 47-48hp on the dyno going from locked to unlocked so I know I'm leaving some ET & MPH on the table.
Do you make a converter with that high of a stall that hits hard off the line and is efficient like the ATI 5500?
Old 10-13-2006, 12:55 PM
LS1Tech Sponsor
The converters we have offered are very efficient , I will have to check on the one your asking about though thats a high stall for sure ,
__________________
Call 888-744-6542
Old 10-16-2006, 12:47 PM
BAIN's Avatar
Thanks. Please let me know.
Old 10-16-2006, 12:56 PM
monicaz28's Avatar
I would also like to know about a 5000+ converter.
Old 10-16-2006, 02:49 PM
LS1Tech Sponsor
I was told today that for now the converters we have listed are all that are available , We will be adding to the line in the not to distant future , but this is it for now guys ,
3000 9.5 lockup
3500 9.5 lockup
4000 9.5 lockup
__________________
Call 888-744-6542
Old 10-16-2006, 10:16 PM
BAIN's Avatar
Too bad. Nobody makes a 5000+ stall for a 4l60e
Old 10-16-2006, 10:47 PM
buffman's Avatar
Im sure there's someone who makes a 5000+ stall for the 4l60e..
Old 10-16-2006, 11:27 PM
LS1Tech Sponsor
yes im sure someone does , we will soon also im sure !
__________________
Call 888-744-6542
Old 10-18-2006, 01:07 AM
LS1Tech Sponsor
bump up up up
__________________
Call 888-744-6542
Old 10-18-2006, 06:40 PM
Razor_Blade's Avatar
What is the lead time when ordering one of your converters?
Old 10-18-2006, 08:17 PM
LS1Tech Sponsor
Just a few days .
__________________
Call 888-744-6542
Old 10-18-2006, 09:38 PM
Ragtop 99's Avatar
Yikes, that is a huge power loss.
What are your cam specs that 5300 stall makes sense?
Old 10-18-2006, 09:41 PM
LS1Tech Sponsor
5300 Is One Helluva Lot Of Stall For Sure !
__________________
Call 888-744-6542
Old 10-19-2006, 07:40 AM
BAIN's Avatar
I have a Yank PT 4400 that Yank restalled to a 4800 with a T-Rex cam (242/248 .608/.612 110LSA)
Old 10-19-2006, 08:25 AM
monicaz28's Avatar
Yes, more than one company makes them. The ones that are good are really really expensive though.
Old 10-19-2006, 09:13 AM
BAIN's Avatar
Who makes them?
Old 10-19-2006, 09:21 AM
LS1Tech Sponsor
As of now we do !
4500 550 dollars
5000 650 dollars
5500 750 dollars
__________________
Call 888-744-6542
Old 10-19-2006, 09:25 AM
Yank's Avatar
Over the years in dyno testing converters for the 4l60-e and LS-X motor combos we have found that any converter over 4600 stall will show a big loss on the chassis dyno as the time to collect data is so short, that you get false reporting, as the turbine and pump do not have time to allow for them to reach there coupling phase of operation,
a lot of gear to reduce the work load (4.33 up) will help
Nhra stock class run LS-1 powered cars have 4.56 to 4.88 and a stall in the 5500 range with the help of a close ratio non lock-up transmission to keep the RPMs up after the shift and Efficiency in the 89 to 94% range at the end of run
