drag radials with torque converter
how high of a converter could i probabally go with before i need drag radials in order to hook the tires i am all stock cept for a slight upgraded trans like corvette servo and only plan on being on street
You'll probably need DR's with any aftermarket converter to utilize its full potential. A lot of that has to do with the STR. The higher the STR, the harder it hits and the less likely that you'll hook. Higher stalls will also affect that. DR's should be included in your plans with any TC.
