TH400 guys what flexplate boilts??
LS1TECH Sponsor
I used ARP M6 flexplate bolts on mine. The TCI flexplate is a lot thicker that the stock A4. It works fine. Make sure to clean off all of the powdercoat around the bolt holes on the TCI flexplate. It tends to let the bolts loosen up.
Originally Posted by BTLFEDSS
Called aRP direct and they do not make them.What are you guys running,stock?????????
BTLFEDSS
BTLFEDSS
