OK i got the tranny working but...
I just installed a transgo shift kit 4 my 4l60e and when i drive it doesn't want to downshift until i let off the gas and it wont go into first gear without me manualy putting it in first and even then it sometimes lock up like its ingaging first and reverse at the same time. I started to mess with the servos a little and i think i may have put one in backwards. Would that cause this or is it something else?
no check engine light, the ***** should be in there right, and i dont know what servo i think it was the one that u put the red o-ring on in the shift kit. and i need to rephrase that it downshifts most of the time
LS1Tech Sponsor
well red rubber ring Im asuming your speaking of the 2nd servo in side of the case ,
it is possible to install this reversed , this will cause , 2nd gears starts. Bind in manual low ,fourth gear instead of third where the third shift should happen, and will burn up the 3-4 clutch rapidly , I would post a pic of how it should look but I dont know how to do that in here yet
__________________
