how strong is a stock 4l60e?
Old 10-31-2006, 05:05 PM
Denzzl's Avatar
Default how strong is a stock 4l60e?
hi, im curious about how much hp and torque my stock (level 1?) 4l60e can handle.
Old 10-31-2006, 05:13 PM
transamfreak01's Avatar
there is no positive answer for this one. some people have ran 10's in theirs and others have hit high 12's and blown theirs up. how far are you planning on going with this car?
Old 10-31-2006, 05:23 PM
john kilgore's Avatar
Default performance
three little numbers 3.73 and your car will haul a_ _
Old 10-31-2006, 07:02 PM
chris718's Avatar
with the stock pressure rise system and the largest 2/4 servo usually 400 ft lbs is the limit.this is on a brand new unit subject to such torque.an old in service unit with glazed friction materials,leaky circuits,worn accumulator pins,hard rubber etc. will usually roll over and die when mods are done and the power level is high.besides jks dislike for the ratio in rotating speed the 2/3 clutch circuit is taxed at high rpm . the fluids inability to apply the clutch at high drum speeds causes friction burnup as well as a small area behind the apply piston to compress the clutch pack .we do use them in high power applications but only after reengineering circuits and designing and manufacturing the internal components it needs to survive.http://www.ckperformance.com/resourc...SMISSIONS.html http://www.ckperformance.com/resourc...OMPONENTS.html
Old 11-01-2006, 01:40 AM
Denzzl's Avatar
i was planning on bore it up to a 383 stroker engine. but i got the impression my transmission wouldnt hold for long.. what is the best way to upgrade this weakness?
Old 11-02-2006, 03:06 PM
MeanWS6's Avatar
mine broke within a week after my h/c install; 415-430RWHP
Go TH400 - solid and can take the NA 480rwhp + 250shot ALL DAY
Old 11-02-2006, 03:18 PM
hashtagBMW
Speed Density's Avatar
Grab a glass, drop the glass. Thats your 4L60E at 400rwhp.
Tony.
Quick Reply: how strong is a stock 4l60e?
