what size converters are the dd drivers runnin?
im having a little trouble deciding on a converter thats really street friendly because i drive every freakin day... just curious what size converters you guys are runnin
As you can see, any size converter can be street friendly. It's mostly what YOU feel is acceptable to drive every day with your driving tendencies. You'll lose more city-driving fuel economy the bigger you go with stall speed. If you do most of your driving locked up on the freeway, that may not be a big deal to you. What are the specs of the cam you're getting? That's going to be the biggest factor in selecting your stall speed.
so i have some questions. i want to do a stall after i do headers this weekend. what does it mean when someone says "lock-up" and when some asks if its loose or tight? Also, do u need to change ur shift points when doing a stall? What if ur gonna run a stock cam and gears, is it better to get a smaller stall?
