3200 vig, pt4000 or ss4000 which one?
Old 11-05-2006, 07:34 PM
texada's Avatar
Default 3200 vig, pt4000 or ss4000 which one?
Which converter would you guys go with on a l92 418ci with a mild cam 236/242 600 and ported l92 heads, 3.73 gears. I am also planning on spraying a 150 shot. I am currently running a 3200 vig, but undecided whether I should keep it or sell it.
Old 11-06-2006, 02:48 PM
texada's Avatar
Come on guys
Old 11-06-2006, 02:51 PM
GregWS6&z28's Avatar
I say stay with the 3200 vig on the juice
Old 11-06-2006, 03:08 PM
transamfreak01's Avatar
go with the ss4000 with some juice
Old 11-06-2006, 03:58 PM
Detroitmuscle's Avatar
Ss4000 Ftw
Old 11-06-2006, 05:26 PM
omcar's Avatar
Default 3200 Vigilante
just do it!
Old 11-06-2006, 05:41 PM
Gold Z's Avatar
I would stay with the Vig3200. It should be stalling at around 3600 or better with your setup. Don't ask me why Vig rates their converters differently than the other manufactures but they do. The SS4000 is a very tight converter and I doubt that you will notice any difference between it and the Vig 3200. The PT4000 should give you a slight advantage when on motor but I don't suspect it will be enough of a gain to make the expense worth while. On the juice everything changes. The Vig3200 should stall closer to 4200. The PT4000 should stall at 4400 at a minimum and could be as high as 4800. You may find your engine will just "blow through" the converter causing a loss of time. I went from a 4200 converter to a Vig3200 and gained three tenths in the eighth. So figure anywhere from five to eight tenths in a full quarter mile. I have played with eight different converters by five different companies and the Vig3200 is by far the best I have found.
Old 11-06-2006, 07:18 PM
TurboGoat's Avatar
Originally Posted by omcar
just do it!
agreed
Old 11-06-2006, 07:20 PM
texada's Avatar
Anyone else? Thanks to those who replied!!!
Old 11-06-2006, 08:24 PM
import slayer's Avatar
of those three I would get the pt4000
Old 11-06-2006, 09:42 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Any Yank, all the time.
Old 11-06-2006, 09:49 PM
SDB
SDB's Avatar
Yank just built me a PT3800...tired PI 2800, PI 3400 multidisc, Yank PT4000 (GREAT on motor, blow through on spray), Yank SS3600 (great on spray, too mild on motor), and now getting the PT3800 installed this friday.
I have a 382, big everything, and 175 shot.
I will post how the PT3800 goes. If I were you, I would do a SS3600 or wait until I get a chance to run the PT3800.
SDB
Old 11-06-2006, 09:53 PM
LS1Tech Sponsor
performabuilt's Avatar
Performabuilt 4000 Is what I would suggest .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-07-2006, 02:42 PM
texada's Avatar
SDB
let me know how it works!
Old 11-07-2006, 02:43 PM
texada's Avatar
Never heard of that converter, tell me more about it
Old 11-07-2006, 03:38 PM
BORN2LOSE's Avatar
A while back the rumor was that PI converters were rated originally for the LT1 and they stalled a bit higher on the LS1's because of the higher HP and TQ numbers. Not sure if this is true or not.
