M6 to TH400 Swap - What happens to Rev Limiter?
Old 11-07-2006, 09:12 AM
Johnny5's Avatar
Default M6 to TH400 Swap - What happens to Rev Limiter?
Just curious what happens to the limiter on the car. I'm planning on going to a manual / reverse TH400. I know it has been posted that the PCM doesn't need to be tweaked (barely) for the conversion but I thought that the limiter is by Gear x RPM.
Obviously if you don't shift you'll redline, but if there is no T56 will the PCM still apply a rev limiter?
What am I missing here?
Old 11-07-2006, 12:59 PM
Johnny5's Avatar
Looking at it again in Edit the parameter doesn't fall under the Transmission but there are values listed by gear in the Idle + Limiters tab. I guess all my values are the same and maybe there is no difference between the gears but I have never tried to set it differently by gear either.
Old 11-07-2006, 02:05 PM
GET2IT's Avatar
You should be fine with the swap..
