Need to get car out of limp mode
Old 11-07-2006, 08:49 PM
AutomagicLS1's Avatar
Default Need to get car out of limp mode
Need to get rid of the P0757 code. Where do I get it done. Am i going to have to pay for a liscence for EFI Live or LS1 edit to get it removed? Is there any other options
Old 11-07-2006, 08:52 PM
00turboT/A's Avatar
You can delete it at an autozone. Do you know why its throwing it???? You could also use some VIAGRA Sorry I had to just once
Old 11-07-2006, 09:22 PM
I just put a Yank PT4000 converter in it. The computer is throwing the code b/c its still going off the stock converter thinking its slipping to much PO757 code. The scanners will just remove it i need the code actually deleted or locked out so it wont come back
Old 11-07-2006, 09:51 PM
'Trust''s Avatar
Your going to have to find someone who has HP Tuners, or a similar tuning program to remove it, no other real way around it.
Old 11-07-2006, 10:07 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
LOL!
Old 11-07-2006, 10:52 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
I don't think you should get that code unless you hold the brake and stall it up over 3000 rpm for more than 5 seconds. It should go back to normal mode after turning off the ignition and restarting the car. The code will be stored there, but that should clear the symptoms.
You may want to do a full PCM reset and give the car some normal drive time to learn the new TC.
A full tune would be the correct way to fix it for sure.
Quick Reply: Need to get car out of limp mode
