Built 4L60E
Old 11-09-2006, 02:09 AM
Racer
UL LOSE's Avatar
Default Built 4L60E
What exactly does a "built" 4L60E consist of? Can anyone give me a list of the parts I would need to acquire to "beef up" my tranny before it finally gives out. Right now I have a B&M Cooler and a Vigilante 3000 stall,every other part of it is stock. So what are the parts I need to handle about 600rwhp? Stronger clutches,bands,etc??? What all is there?
Old 11-09-2006, 06:22 AM
FLT
FLT's Avatar
Check out the listings of our level 4 and 5 units. These are the parts that I would use. Then go to our online store and start pricing it out. Vince
Old 11-09-2006, 10:34 AM
Figz Z28's Avatar
Your going to need a bigger oil pan, a stronger shaft, bands, clutches,?????????
Old 11-09-2006, 12:42 PM
Racer
UL LOSE's Avatar
Thanks Ill check that out!
Old 11-11-2006, 03:36 AM
Racer
UL LOSE's Avatar
What about spraying through the shifts on a FLT Level4? I understand that if you dont spray the shift it will last longer but is this level trans. built to take that kind of abuse?
Old 11-11-2006, 06:02 AM
FLT
FLT's Avatar
We don't recommend spraying through the shifts on any of the 4l60e based units. Most guy's use a window switch and they work well with this method.
Old 11-11-2006, 10:50 AM
LS1Tech Sponsor
performabuilt's Avatar
Depends on the setup if it was a 75 or 100 shot with our LEVEL 2 or Level 3 I wouldnt worry about it , With higher setups then I would use the window
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-11-2006, 01:53 PM
Racer
UL LOSE's Avatar
I have a MSD Window Switch now that I use on my 150 shot. Was just wondering. Guess Ill still to the switch. Thanks
Old 11-12-2006, 01:24 AM
LS1Tech Sponsor
Also note the write up we have for our transmissions in all three levels is very detailed on our website
__________________
Call 888-744-6542
