PT4000 guys, quick ? for you....
What are launching at? I haven't had a whole lot of time to play with different points yet, but so far the best 60 ft i've had is a 1.72 on a SI car with lt's, duals , lid, 3.42's and a tune leaving around 1800-1900. I tried a little over 2k and it spun. Some told me that 1.72 was not very good, so i'm trying to get a feel of what I need to do, launch off idle, stall it till the brakes are about to give?
Thanks
Thanks
"All Motor 9 Second club member"
My ST3500 liked to be stalled up as high as I could get it before pushing through the beams.
My PT4200 was not too sensitive to the stall rpm, but it did yield slightly better 60fts with a max rpm stall at the launch.
I pulled 1.42 60fts with it when I was a H/C and with the 383 stroker.
You definitely need a sticky tire to get maximum benefits from that TC.
Good luck!
Good luck!
