Some 4L80E Questions
Is there any specific year I should look for, or just any 4L80E? A buddy of mine has one that needs a rebuild he'll let go for cheap, but he doesn't know what it came out of.
Does the bell housing bolt right up, or is there a conversion peice?
Does anyone make a RMVB w/ a brake for the 4L80E?
What shifter works w/ this trans?
You will need a 97+.. The older ones will work but will need some modifications. They are also not as strong. The bellhousing will bolt up, youre going to need a converter made to fit the 4l80e but yet bolt to the LS1 flywheel. The PCM has to be modified, you'll need a crossmember, a wiring harness, TH400 slip yoke and the stock shifter will work. The stock drive shaft will also be fine. I think thats about all I can think of right now.
Originally Posted by calongo_SS
Is there any special mods that the builder will need to know about when putting this trans together to make it work in a f-body? (internal, input/output shafts, etc..???)
cool, thanks.
Is there anyway to tell by looking at the trans what year vehicle it came out of? My buddy thinks it came out of a 99, but I'll be pretty upset if it's a 95 or something and I dump a bunch of $$ into it.
The trans itself will have the model on it. Mine has 4l80e right on the side of the casing. Only other thing you will need to know is the year model it came out of. Someone your suppose to be able to tell that by the part #.
Did he not know or did he just not reply?
he didn't reply. I really hope this trans my buddy has is the right year, it sure would save me some cash.
