4L60E replacement issue
formerly 1BADC10 (12/14/2011)
I recently bought a 4L60E from a trans shop out of Tampa. The reason I did this was b/c it was "supposedly" built stronger than stock, and was priced pretty nice. I received it earlier today, and got home to find that the bellhousing on the new one versus the old one are different. The input shafts are also different. The bellhousing can be changed w/o issue. My concern is the input shafts. Any help on this would be great... as I'm getting angry with this entire experience. BTW, I am attempting to bolt the new trans to a 5.3L. My PTC 3000 TC seems to fit without issue, but I get opinions that this will not work properly.
Both transmissions - old on right, new on left
The old trans
The new trans
The old trans
The new trans
LS1Tech Sponsor
will not swap for several reasons if you install the vehicle will not move due to the difference in the shaft , but also if you install the LS1 converter with the new trans you will destroy the pump due to a clearance issue ,
sorry to be the bearer of bad news
__________________
Originally Posted by Vince @ FLT
The input,pump,and belhousing would have to be swaped.
Now, the real question is how much "work" is it to do this, as a novice? Recommended or not... to DIY or find a good builder?
