98 computer running a 4l80E
Old 12-04-2006, 09:37 AM
csmc711's Avatar
Default 98 computer running a 4l80E
can a 98 computer run a 4l80e using efilive to reset it?
Old 12-04-2006, 11:45 AM
jmm98LS1's Avatar
Someone correct me if I'm wrong, but I'm pretty sure the only way to run a 4l80e on a '98 pcm is to buy an aftermarket controller to run it.
Old 12-04-2006, 11:56 AM
csmc711's Avatar
that why I am wondering. I was thinking of just keeping my 98, but, if that is one more reason to go with a 99+, then that just ties the knot for sure.
Old 12-04-2006, 09:11 PM
camaro98z28's Avatar
Is there a difference?
Old 12-05-2006, 08:18 AM
csmc711's Avatar
I know 98 computers and 99+ computers are in some way differant where the fact that the 98's are not as tuneable as the 99+ computers. With that in mind, I need to make sure that the 98 can be as easily tuned, or not, to the 4l80e as the 99+ computers.
Old 07-21-2014, 11:15 PM
NOS LS1's Avatar
Default 1998 Computer will operate the 4L80E Transmission
I own a 1998 Camaro with a 4L80E Transmission.
My Trans guy told me all he had to do is download a truck file in my 98 Camaro that will operate,shift & lockup my lockup stall converter. He used HP Tuner software to fine tune the shift points, shift firmness & to lock up my converter in 4th gear only. Im running a Billet FTI 4L80E Lockup converter at this time.
Believe me... the 4L80E is the strongest transmission that you can run in your F Body that HAS Overdrive. Im running a stock 4L80 trans with a Trans Go 2 Shift kit. We are spraying a 100 shot of nitrous now & our Camaro hauls azz & shifts fine.
Old 07-22-2014, 09:13 PM
mjs1012's Avatar
Why did you bring up an 8 year old thread.
Quick Reply: 98 computer running a 4l80E
