99 to 01 4l60e
Old 12-05-2006, 05:33 PM
volumebikertom's Avatar
Default 99 to 01 4l60e
I've got a 99 z28, auto. and just picked up a cheap 4l60e out of a 01 car. It needs a new shift band. I looked up all the GM specs, at work since I work as a GM tech. Everything was exactley the same, except the torque converter turbine was 300 mm on the 01, and 298 mm on my 99. Will this make a difference when installing it with my 99 torque converter? thanks for the help.
Old 12-05-2006, 05:41 PM
02 BLK WS6's Avatar
It will work and be fine.... '98-'02 LS1 4l60E's are the same/interchangable....
Old 12-05-2006, 06:52 PM
LS1Tech Sponsor
performabuilt's Avatar
Correct they are the same
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
