Trans Brake with a 4L60E
Just like it says. Is this a wise choice? Consider the car wont be at the track no more that 4 times in a year. Can I save the tranny with continued and regular fluid changes like about every 6 months or is this a waste of money? Who sells a Trans Brake? Thanks guys, MERRY CHRISTMAS!!!
Chad
Chad
Chad
Chad
Transbrakes for 4L60E are not cheap either. I think rossler makes one and its about $600. Here is one for a 4L80E:
http://www.rosslertrans.com/4l80e.htm
You'll want to get just about every part upgraded in that tranny, not just a rebuilt. Upgraded planetaries, hardened input/output shafts, sun shell, upgraded clutches and band, servos etc. Rossler is the only one I know that makes a t-brake for the 60E that still allows the computer to do it's thing.
Originally Posted by 1320FEVER
If your not running at least a 28" slick I'd say a transbrake is a waste of money. You'll just smoke your tires otherwise and it won't help your et one bit.
A transbrake is very beneficial in cutting a good light. Not to mention a properly setup car that has a transbrake will hook better than a car with just a stall.
Originally Posted by Enthusiast
Ever heard of suspension tuning? Aside from the fact that this is wrong.
But the guy, judging from his mods, is not to that point in his car that he would benefit from a transbrake. At this point, it would be a waste of $600 which he could use for something else. If you read his statement he says: "Consider the car wont be at the track no more than 4 times in a year."
Simply throwing a transbrake on a car with street tires and minimal suspension mods is not going to help his et. And I believe his money will be better spent on something else at this point.
That was my point. You missed it entirely.
Thanks 1320Fever, I realize that having slicks is going to be a MUST in order to benefit from the trans brake. I went to the track this past Sunday and cut my first 12 second pass on warm tires because it took 30 minutes to get to the track. After I sat in the pits shoot'n the bull with other drivers and let the tires cool down I was unable to get the same speed and trap times as I was before because of traction problems. So I will be getting a set of slicks to run on the track (gotta ask what size wheel & tire fits under my lowered car) but I was more concerned about making the 4L60E last or if I did buy the T B then my 60E takes a dump, can I use it in a new 4L80E that is stronger and able to take the every so often abuse of a track? My 60ft times are horrible, I have yet to get under a 2.00. I have a Vigilante 3200 stall waiting to go in and then have the car retuned and then returning to the track for some numbers, I met a guy at the track who had a TB and it was awesome. Thought I would look into getting one, thanks for the advice!
Chad
Chad
LOOKIE HERE![IMG][/IMG]
C5 4l60 from RPM TRANNSMISONS. t-brake forged input output shafts 5 pinion and of course rodney's special recipie. i have run 30 145 passes with NO issues, granted no w/t-brake but.......
RPM RULES
RPM RULES
