View Poll Results: what should i do ?
keep stall and shim it
0
0%
new stall no shim
1
50.00%
new stall shim
1
50.00%
change over to m6 with lightend fly wheel etc..
0
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
trans gone out again Help!4th time
Old 12-11-2006, 12:50 PM
lilicedout24's Avatar
Question picking a converter
ok fellas going to stay a4 now i trashed the custom built stall with that 3500 and 342 gears i ran 12.5 at track.now ihere vigilante s better than yank on the streets or tci 3500 or performance built 3500 so ill do what i always do leave it up to u guys to clear it up and should i go with a larger stall? i plan on order 1 first thing in mornin any help good thankx
Old 12-12-2006, 02:19 AM
02 BLK WS6's Avatar
Is the converter not fully seated in the pump???? When you put in the converter, how much of a gap was there between the converter and the flywheel?
Old 12-12-2006, 08:36 AM
LS1Tech Sponsor
performabuilt's Avatar
can you get pictures of the inside of pump and the converter hub and the exact converter hub to bolt mounting surface height ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-12-2006, 01:15 PM
ill tear it down this week. the guy who built it says that the converter was built to short for shaft some **** likt that do that sound right?
Old 12-12-2006, 01:32 PM
LS1Tech Sponsor
sounds odd but get those pics and measurments and we shall see what we can figure out
__________________
Call 888-744-6542
Old 12-15-2006, 03:12 PM
ok need stall now got a flywheel
Old 12-15-2006, 03:22 PM
Yank's Avatar
Give us a call and we will help anyway we can
at 775 826 9955
Old 12-15-2006, 03:26 PM
LS1Tech Sponsor
Please check out what we have in stall also and or give us a call
thanks
__________________
Call 888-744-6542
