Converters... You get what you pay for
Old 12-20-2006, 05:44 PM
The1N_only's Avatar
Default Converters... You get what you pay for
First off, i would like to say that Frank from Performabuild is an awesome guy, and he works for a great company and has helped through every step of the way. Hell i didn't even buy their converter and they still went out of their way to help me. I would recommend them to anyone As far as the Converter goes ill let the pictures are worth a 1000 words. My suggestion is if you have any doubt, go with a company like PI, Yank, or Precisionshift... they cost a little more, but it would have been a whole lot cheaper is i would have went one of them to start with
As you can see this caused my tanny to overheat extremely bad
Look at the shitty welds
This is whats left of the lock up clutch
The1N_only is offline
Old 12-20-2006, 06:25 PM
GMRACER13's Avatar
I see these all the time. All it is is a 4 cyl. converter with an adapter ring or adapter lugs welded on so it will bolt to a V8 flywheel and 4L60E hub welded on to mate with the pump. In the first pic you can see where the adapter lug is bolted with an allen bolt to the original 4 cyl. lug in order to make it fit a flexplate with a larger bolt circle! The lock up clutch isn't large enough to handle the weight and torque of a V8 powered F-body. The clutch in that convertor is approx. an inch wide where as quality stall convertors have clutches that are more than twice as wide as that. This is the reason why companies like PI or Yank have billet front covers specially machined. In order to get a lock-up clutch in a 9"-10" convertor with the same surface area as the stock lock-up clutch you MUST use a custom made front cover with a larger surface area in conjunction with a wider clutch. Do some searches and look at some pictures of aftermarket high stall convertors for the 4L60E. You will notice that the expensive ones ALL have a billet front cover (the side facing the engine which bolts to the flexplate) and all the inexpensive ones don't.
I know people are going to come in here and say "I have brand X convertor and have no problems" and "You don't know what you're talking about newbie" and the only response I can give is that you are in the minority and have somehow been lucky. Others will say, "For the price who cares. I'll take my chances". Just know that when the convertor has a catastrophic failure it usually damages the transmission (i.e. $$$$$). Some people will learn from your misfortune but the vast majority will have to learn the hard way.
GMRACER13 is offline
Old 12-20-2006, 07:00 PM
TonyGXP's Avatar
Amen.... went TCI, blew it up and learned the hard way.... VIG is the only way to go
TonyGXP is offline
Old 12-20-2006, 07:07 PM
The1N_only's Avatar
I just wanted to put it out there and so maybe people can see, you actually do get what you pay for... Company "X" talked about how good there converters was and the quality and yadda yadda yadda... well as you can see, IMHO its a peice of ****
Old 12-20-2006, 07:38 PM
2002_Z28_Six_Speed's Avatar
Where were you when all certain people [not NOT talking about Performabuilt] were fleecing the users on this site and they were/are still loving it?
2002_Z28_Six_Speed is offline
Old 12-20-2006, 07:56 PM
The1N_only's Avatar
Originally Posted by 2002_Z28_Six_Speed
Where were you when all certain people were fleecing the users on this site and they were/are still loving it?
Old 12-20-2006, 07:58 PM
The1N_only's Avatar
Oh i forgot to mention, I only put 250 miles on this converter and new tranny set up
Old 12-20-2006, 08:12 PM
vMaster0fPuppets's Avatar
was that a performabuilt converter
vMaster0fPuppets is offline
Old 12-20-2006, 08:40 PM
Not4Racin's Avatar
Anyone familiar with PTC in Mobile AL?
Is this what they do , adapt 4-cyl convertors?
Not4Racin is offline
Old 12-20-2006, 08:53 PM
sixvi6-camaro's Avatar
From the mounting tab and color of the case... looks fuddlerific to me.
Did it Let go? Break anyhintg in the tranny?
sixvi6-camaro is offline
Old 12-20-2006, 08:58 PM
12345678910's Avatar
was it performance built i just ordered a transmission and converter from them
12345678910 is offline
Old 12-20-2006, 09:01 PM
Its NOT a performabuilt converter.. he said that in the first post. Its a Performabuilt Tranny but another brand converter.
Old 12-20-2006, 09:06 PM
OK, I was confused by the structure of his paragraph. I just installed a Performabuilt trans and converter, and though I've had no serious problems, a post like this worries me. Damn Fuddle.
01WS6/tamu's Avatar
A while back everyone was praising fuddle now bashing them. I have not used any of their converters but whats the deal with everyones change of heart they used to be/ are a sponsor here arent they.
01WS6/tamu is offline
Old 12-20-2006, 09:26 PM
LS1Tech Sponsor
performabuilt's Avatar
No as The1N_only said that is definatly not our converter just wanted to make sure that was clear. Our converter brand name is PrecisionShift converters.
We did inspect the transmission for him the damage was not severe and was limited to considerable contamination with aluminum mostly
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
performabuilt is online now
Old 12-20-2006, 09:32 PM
Quickin's Avatar
What kind of low-life shop does this and sells it to people?
Quickin is offline
Old 12-20-2006, 09:34 PM
Quickin's Avatar
Just don't drive it and you'll be fine. j/k I don;t know who's it is, yet.
Quickin is offline
Old 12-20-2006, 09:36 PM
Quickin's Avatar
For the record, my brand new (4 months old) VIG 3700 exploded while driving steady at 45 mph and destroyed my ALSO 4 month old FLP IV tranny......so it doesn't matter who you go with really.....but you might as well go with the top people to better your chances.
Quickin is offline
Old 12-20-2006, 09:42 PM
Trunion King
bene's Avatar
Looking at his sig, his stall is YANK.
bene is offline
Old 12-20-2006, 10:38 PM
05gto60's Avatar
thats his new one. the one pictured isnt a yank. a couple other people have said who it is.
i wonder if this was my problem too. i had the same company's converter go bad through my trans.
05gto60 is offline
Quick Reply: Converters... You get what you pay for
