TH350 swap into LT1,4L60 question
Old 12-25-2006, 03:34 AM
GTP PWR's Avatar
Default TH350 swap into LT1,4L60 question
is it a direct bolt in? what do I need?
I have a midwest converter, and the trans has been gone through and freshned up a bit.....
what else is needed?
also, I have a 4L60 in my LS swapped S10. what type of thread pattern is used for the cooler lines that screw into the trans? I am going to be using -6 line...just need to know what fittings to order. any imput would help out.
Quick Reply: TH350 swap into LT1,4L60 question
