trans is jerking
Old 12-28-2006, 09:26 AM
barthowell's Avatar
Default trans is jerking
i have a 4l60e with a level 3 build to handle a lot of hp. the only problem is as long as i'm accelerating the car is fine but when i'm cruising between 15 to 50 mph or i slow done the trans starts jerking. if i speed up it stops or if i put on the brakes it stops. any ideas what this might be. i have a 408 with a trex cam i don't know if that will help solve the problem. any advice would be appreciated
Old 12-28-2006, 09:33 AM
LS1Tech Sponsor
performabuilt's Avatar
Ok the jerking could be several things but what comes to mind most particularly if you have a large cam is the converter not unlocking this will cause a sensation very similar to a standard shift when slowing down in to high a gear without he clutch depressed ,
and based on the fact that it stops when you apply the brakes I would say thats what it is , You will need to have the tuning checked to see if the converter unlock parameters are correct (the speed at which it locks and unlocks)
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-28-2006, 09:37 AM
RICEETER's Avatar
my guess is gonna be cam surge
Old 12-28-2006, 09:40 AM
LS1Tech Sponsor
That sounds right that accompanied with the converter not being commanded to unlock at the proper time making it very noticable
__________________
Call 888-744-6542
Old 12-28-2006, 11:16 AM
barthowell's Avatar
thanks, that is exactly what it is doing. its like i'm driving a standard in to high a gear when i slow down. what kind of numbers should i be looking at for shift points. i have hp tuner is there any place that shows what kind of numbers i should have. i just have the stock 3.23 gears in it.
Old 12-28-2006, 11:50 AM
LS1Tech Sponsor
Im sorry but I cant help you there i dont have much experience with the tuning side , I would consider posting another thread that says (converter not unlocking on decel causing surging tuning help please)That may get some of the tuning guys attention
__________________
Call 888-744-6542
