P0101 and TCC issue
Old 12-29-2006, 02:23 PM
Joel_SS's Avatar
Default P0101 and TCC issue
Anyone know if this code will keep the TC from locking up properly?
Here is an explanation..
http://www.gearchatter.com/viewtopic10728.php
Old 12-29-2006, 02:43 PM
LS1Tech Sponsor
performabuilt's Avatar
I don't believe it could directly , But a faulty MAF could cause misfire which could cause the PCM to disallow lockup
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-29-2006, 02:45 PM
Joel_SS's Avatar
Hmm.. Well I just scanned my car and it says the TCC is being commanded to lock up.. But the TCC seems to slip when I give it gas and my trans temps are up about 50 degrees from normal.. I have a brand new Yank SS4000 it worked frin for the first 1200 miles.
Old 12-29-2006, 02:46 PM
DRIVER456's Avatar
P0101 is MASS AIR FLOW SENSOR PERFORMANCE.I had that but it was after I put on a ZO6 85mm MAF,I tuned it with EFILive,But I don't remember it affecting the TC.Can you clear it? See if it comes back.
Old 12-29-2006, 02:49 PM
DRIVER456's Avatar
Temps will go up with a higher stall.Do you have EFILive? Or did someone else tune it?
Old 12-29-2006, 02:51 PM
LS1Tech Sponsor
Is the pwm duty cycle set to max (Converter clutch duty cycle) or the pwm disabled in he VB
__________________
Call 888-744-6542
Old 12-29-2006, 03:00 PM
Joel_SS's Avatar
Yes I have efilive.. And the temps are higher than they are when the TCC was locking up.... I do not believe that PWM is disabled, not sure though.. Also though When scanning I see the duty cyle ramp up to 100% when it is commanded to lock.
Old 12-29-2006, 03:04 PM
DRIVER456's Avatar
Try setting {5601} MISFIRE DETECTION MAX TEMP to 1 degree and see what happens,You can always set it back.is the car at normal operating temp?................Paul
Old 12-29-2006, 03:06 PM
Joel_SS's Avatar
Already have done that...
Old 12-29-2006, 03:14 PM
DRIVER456's Avatar
Trans oil level? Did you change anything else besides the TC?
Old 12-29-2006, 03:17 PM
Joel_SS's Avatar
Oil level looks good.. I had a local shop rebuild the tranny for me the same time the Yank went in.. I will probally take it back to them next week to have them look at.. I just want to know what is going on casue I suspect they will just blame it in the converter since I did not buy one of thiers.
Old 12-29-2006, 03:26 PM
DRIVER456's Avatar
Aaahhhhh you did not fill us in on that part,Thats your best bet,Bring it back.
Old 12-29-2006, 03:33 PM
Joel_SS's Avatar
Is there anyway to tell if the TCC solenoid is giving enough pressure to hold the TCC nice an tight? My fear is that they will blame the converter and I will pull send to Yank and they find nothing wrong with it.. I just do not have time or money to play games like that..
Old 12-29-2006, 03:48 PM
DRIVER456's Avatar
Yea I hear ya on the games.Did they mess with the valvebody at all? EFILive has a bunch of tranny pids go through them and see if you can come up with something before you bring it back.
Old 12-29-2006, 03:53 PM
Joel_SS's Avatar
They put a shift kit in it so I suspect they messed with the valve body.
Old 12-29-2006, 03:59 PM
DRIVER456's Avatar
Do you still have the P0101 code?
Old 12-29-2006, 04:41 PM
Joel_SS's Avatar
Yes, I have not cleared it yet.. Although the SES light is not on, but the "Brake" light is on. But the brake light was on before the TCC started having issues.
Old 12-29-2006, 04:45 PM
DRIVER456's Avatar
Clear it and see if it comes back and if not see if thats whats causing your TC problem.Process of elimination.
Old 12-30-2006, 02:28 PM
Joel_SS's Avatar
I cleared it and the same result.
So I command the TCC to lock via the EFILive scan tool and nothing happens.. I tried it while stopped and I guess if it engaged it would kill the motor, but it did not the RPMs stayed at a steady 1000rpm idle speed. SO I would guess the TCC soleniod is shot?
Old 12-30-2006, 04:24 PM
DRIVER456's Avatar
Drain the trans oil and drop the pan and change it and see what happens.Do you have any ramps/tools to do it?There is a valve for the TCC ,Its possible it got hung up................Paul
