4l60 broke yesterday
i dont know what happend,i stoped for gas and when i pulled out no 3dr or 4th i pulled over,turned it off,restarted it,still no 3rd or 4th.so i stopped again unhooked the bat,tryed it again,still no work soi just kept driving. i did notice it does try to shift into 3rd but just revs lik it's neutral
whats wrong with it??
Originally Posted by ohsofast
How long did your trans last with your mods
i was hoping it would last on motor,just not on spray
who can build one the will take the mods i got for dd,and some spray at the track???how much do they cost??
Originally Posted by performabuilt
please check our website and look at our level 2 and 3 units
Just disconnecting the battery won't reset the PCM. (unless your setup is different with the swap)
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
My car (not me. lol!) has gone into "limp mode" a couple times. It's worth a try resetting PCM.
There´s no doubt, your tranny is dead.
You will need to full reparation, so please, dont just replace 3rd and 4th discs, replace the entire kit and full reparation.
Check the pump and all pieces to correct oil pressure so dont broke again your trany soon.
the 4l60e when built right will perform very well. the 4l80e is going to add more weight to your drive line.
im sure one of the fine transmission vendors on this site are able to built a good performing 4l60e with a warranty to boot. Just make sure you take the right preemptive steps to make sure your tranny lives a long life.
