tranny help
tranny help
I have a 2000 camaro ss with an auto. Every gear shift fine except when it shifts from 2nd to drive it hits the rev limiter 8 out of 10 times. We went in and adjusted the shift points and still does the same thing. Any help would be great.... the car has 65000 miles on it
Retired Street Racer
Do you mean 2-3? Not 2-D? What size converter and what shift points & rev limiter? I had the same issue with my car and fixed it tonight. I have a 4500 converter and had all of my shift points set at 6000 with the rev limiter set at 6500. I banged the 2-3 rev limiter as well. I dropped the 2-3 shift point via HP Tuners to 5100 and now it is shifting at 6200 without hitting the rev limiter. I am going to drop it down another 200 to see if I can get it right at 6000. Try that and see if it helps.
LS1Tech Sponsor
I would try what MATT said and lower the shift point , Many times people fail to realize that there can be considerable delay between the electrical command for the shift and the mechanical reality of the shift, moving parts take time to move in to position and the 2-3 shift in particular has alot more going on than the other shifts
__________________
