tranny cooler qustion
Old 01-12-2007, 03:11 PM
snakesmash'nLS1's Avatar
Default tranny cooler qustion
I have a 98 z and Im replacing the trans because my old one BURNT up and I was wondering when I install my new trans cooler should I route the lines straight to my new trans cooler or through the old one and then into the new one and back to the trans. It is the big cooler form B&M. Thanks for any input.
Old 01-12-2007, 03:31 PM
mitch_04's Avatar
I would run it through both. It will just keep things simplier, otherwise you are leaving open holes on your old one, and that could get build up in it and who knows after that. Besides, two is always better that one hup hup. Unless of course its a kidney removal...
Old 01-12-2007, 03:38 PM
I guess thats true but the reason I asked is because the old one faild to begin with and thats how I ended up here.
Old 01-12-2007, 04:47 PM
99Hawk262's Avatar
I bypassed my stock cooler and only run a B&M 24K and my temps with my old 3500 stall stayed around 150-160 while cruising and 180 or so in traffic. I don't know yet with this 4000 stall since I only installed it yesterday, but they seem to be slightly warmer.
Old 01-12-2007, 05:09 PM
yeah Im putting in a 3500 stall. any one else
Old 01-12-2007, 05:46 PM
2001NBMZ28's Avatar
I have a B&M 24K, mounted "dope style" horizontally on the passenger side - didn't bypass the stock cooler.
Old 01-12-2007, 08:39 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Originally Posted by Urban Legend
I run this bad boy. This is just for illustration purposes. This link belongs to a non sponsor.
http://store.summitracing.com/partde...5&autoview=sku
Run the above and bypass the stock cooler.
Old 01-12-2007, 08:48 PM
Montec's Avatar
BYPASS THE STOCK COOLER. there is a long thread with pictures about this very subject. should still be on this page...maybe. give it a look!
Old 01-12-2007, 10:42 PM
https://ls1tech.com/forums/automatic-transmission/635536-tranny-cooler-question.html
Old 01-12-2007, 11:00 PM
00cls1camaross's Avatar
i used both coolers on mine... mine too is mounted dope style and i dont really know if it helps because i dont have a verter or a tranny temp gauge
Old 01-13-2007, 08:29 AM
Thanks guys Im going to bypass the stocker. only my secound time to the track and the stocker failed and cost me a trans and after the advice here Im bypassing thanks for the input.
Old 01-14-2007, 09:06 PM
Arrambide's Avatar
Which is your B&M model cooler? 70264?
Old 01-14-2007, 09:14 PM
2001NBMZ28's Avatar
Yeah, that's the one.
Old 01-15-2007, 11:25 AM
mach2004's Avatar
One more vote for bypassing the factory cooler and just running the aftermarket cooler.
Old 01-16-2007, 05:27 PM
ryle's Avatar
I just had the same problem. This time i'm bypassing the stock cooler. I was talking to a speed shop and they told me that when you run the B&M in line with the stock cooler that you aren't really going to get the trans temp much cooler your coolant. Maybe that's why our transmissions have both blown.
Old 01-16-2007, 06:05 PM
Montec's Avatar
thats what ive been saying!
unless your car is running sub 170* temps your stock cooler will have little to no effect trying to cool the trans fluid.
But the cooler does help when its -10 outside, because it WARMS the trans fluid.
Old 01-16-2007, 07:03 PM
It never gets near -10 down here in florida. But now Im waiting on my trans to come in so I can finish this thing up. Im wanting to see how cool the B&M cooler keeps the temps with a 3500 stall. I drive my car hard and if it gets to hot I thought about running two coolers.
Old 01-16-2007, 09:20 PM
Montec's Avatar
run a small fan with your cooler.
Old 01-16-2007, 09:29 PM
GT Griller's Avatar
I run 2 coolers and bypassed the stock cooler..
Old 01-16-2007, 10:08 PM
LS1Tech Sponsor
performabuilt's Avatar
Well the trans as you know is on the way and I would bypass the cooler for sure in Florida and use the largest possible i like fluildyne , And place in a place with good low speed air flow or install fans on it in the land of perpetual summer
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
