94-95
94-95
me and a guy in nm traded transmissions . he had an auto and ihad a stick .we traded trans , wiring harnes , pcm , everything you need to do the swap . he put it all in and his car will not start unless you jump the relay for the fuel pump . his relay and the pump seem to be working fine . his car is a 94 camaro and my car is a 95 firebird . is there a difference in the wiring harness andif thereis wht should he do ?
