How are the tranny cooler lines properly installed?
Old 01-24-2007, 02:40 AM
vindeezl's Avatar
Default How are the tranny cooler lines properly installed?
In my haste to remove the motor / trans from my '95 Z (A4), I seem to have forgotten how the hell these transmission lines hook up / which end is which / installed where etc. etc. It seems I keep trying to put them in the wrong place and they don't come even close.
I know one seems a bit longer and they both have one end that is rubber / flexible for easier removal I guess.
Does anyone have a pic of the cooler lines in their car or a pic link or have a manual scan that shows how and where these are installed?
Thanks!
Old 01-24-2007, 10:24 AM
12secSS's Avatar
Trans:
Top = Inlet
Bottom = Outlet
Cooler:
Top = Outlet
Bottom = Inlet
Old 01-27-2007, 02:16 AM
vindeezl's Avatar
So you're saying that the top hole on the trans goes to the bottom one on the radiator and vice versa then correct?
Does the removable rubber end go on the transmission or radiator side?
Where do they fit through? Does anyone have a pic showing this?
I think I keep trying to put them through ion the wrong spot and that also is not helping.
Thanks!
