Where do you add ATX fluid?
you can add directly to the tranny or throught the dip stick tube that SHOULD be there.
Since you have an auto tranny, im moving this to the automatic tranny section, so you can get a better response there
tube "should" come up over the intake manifold on the right side and have a red locking dip stick. If you can't find that put the car up in the air and the hole for the tube should be on the right side of the trans. If there's no tube then the hole has to be plugged some how.
