Help With Th400 Swap Brake Problems
Old 02-02-2007, 02:01 AM
azibit's Avatar
Default Help With Th400 Swap Brake Problems
IM SWAPPING TO A TH400 AND JUST CHANGED M6 PEADLE'S TO A4 PEDDLES AND NOW I CANT FIGURE OUT HOW TO GET MY BRAK LIGHTS TO WORK...CAN SOME ONE HELP........
Old 02-02-2007, 04:12 PM
LPTXZ28's Avatar
Youare just gonna have to adjust on the switch at the top of the pedal assy. to get it right
Old 02-02-2007, 10:22 PM
azibit's Avatar
when i plug the switch in it doesnt work at all even when in push it with my finger not screwed into the pedal yet
Old 02-04-2007, 12:53 AM
azibit's Avatar
ttt......for the night crew
Old 02-04-2007, 12:57 AM
98turbls1's Avatar
You sure that you don't have a fuse burnt out?? Do you have a test light of any sort?? I would test the plug and make sure that power is getting to you and when you're pushing it in that it's connecting to the other side...
Old 02-04-2007, 01:17 AM
azibit's Avatar
what fuse could it be?
Old 02-04-2007, 01:18 AM
azibit's Avatar
im ghonna test the circut now with a test light
Old 02-04-2007, 01:39 AM
azibit's Avatar
not the plug showed pwer what else do you think it could be guys helppppppppp.....frusterating
Old 02-04-2007, 02:00 AM
98turbls1's Avatar
Hmmm.... What you should do is pull the lights out of the taillights and check them to see if they're getting power...It's gotta be something in there...Are you sure that both lights are freakishly burnt out all of a sudden??
Also, when you pushed the brake in and checked the other side did it make a complete circuit??
