2-3 SHIFT SOLENOID FAILURE SYMPTOMS - LS1TECH
Automatic Transmission 4L60E | 4L80E | TH350 | TH400 | TH2004R | Powerglide | Converters | Shift Kits
Thread Tools Search this Thread
Old 09-01-2002, 01:59 AM   #1
CWK
Default 2-3 SHIFT SOLENOID FAILURE SYMPTOMS
ANYONE KNOW? IF SO PLEASE EXPLAIN SOME OF THE SYMPTOMS THANKS IN ADVANCE
CWK is offline   Reply With Quote
Old 09-01-2002, 07:53 PM   #2
Default Re: 2-3 SHIFT SOLENOID FAILURE SYMPTOMS
TTT
02RED Z is offline   Reply With Quote
Old 09-03-2002, 04:25 PM   #3
TR
I replied to your PM with some info, LMK if it helps you out.
TR is offline   Reply With Quote
Old 09-03-2002, 09:30 PM   #4
gwj
Location: Live Oak, FL - in the woods where the creatures lurk.
Are you setting any DTCs? Which ones?
When it fails to shift, can you stop, shut the ignition off, restart and boogie and all is good for a while? What year is your car?
Info, dammit man. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
TR has been down that road before. <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> P075?
gwj is offline   Reply With Quote
Old 09-03-2002, 11:23 PM   #5
CWK
thanks guys i had a faulty 2-3 shift solenoid , problem is gone thanks again.
Old 09-04-2002, 10:58 AM   #6
LS1Tech Co-Founder
Pro Stock John's Avatar
On my 99Tahoe, I get an SES lite and the truck went into limp mode, for when I had a bad 1-2 shift solenoid.
Pro Stock John is offline   Reply With Quote
Old 09-06-2002, 09:52 AM   #7
Mike's 01WS6's Avatar
Ive had 2 01's screw up 1-2 and 2-3 and another guy at work has had the same thing happen to 2 02's.
Mike's 01WS6 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
bent torque arm symptoms Ws6Dnero Suspension & Brakes 4 08-30-2012 10:08 PM
Symptoms of shift solenoid failure?? F-BodyMind Automatic Transmission 1 03-26-2011 09:56 PM
Symptoms of a Leaking Exhaust Manifold Gasket? Greekey Generation III External Engine 1 08-03-2010 07:03 PM
Hole In Piston symptoms TermnEatr Generation III Internal Engine 11 11-15-2009 05:32 PM
Symptoms of bent valve or pushrod C_Rules LT1-LT4 Modifications 1 04-18-2009 04:51 PM
Tags
23, 4l60e, 4l80, 4l80e, automatic, bad, failure, faulty, shift, signs, solenoid, solenoids, symptoms, syptoms, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
