What exacly is it?
Old 02-13-2007, 10:16 PM
goodrich969's Avatar
Default What exacly is it?
I searched and I honestly couldnt find a clear cut answer. I even searched jegs and summit for it and I cant find anything. What is a trans break, where do i find them, and how do they work. Sorry if this is a stupid question but I had to ask. Thanks
Old 02-13-2007, 10:22 PM
LS1Tech Sponsor
performabuilt's Avatar
Ok a trans brake is simply a device that locks two oposing gear sets in oposite directions so nether can move effecivley stopping the car from moving
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-13-2007, 10:31 PM
okay so kinda like a line lock? Where can I find a trans break? Thanks
Old 02-13-2007, 10:33 PM
LS1Tech Sponsor
what do you want it for ?trans wise
__________________
Call 888-744-6542
Old 02-13-2007, 10:34 PM
I mean it would be used on a 4l60e.
Old 02-13-2007, 10:35 PM
SuperZ's Avatar
you push the transbrake button and it locks the trans you can then take the RPMs up to the true stall speed,then you release the transbrake and floor it and hold on.Here are some vids of cars with them
TB1
TB2
Old 02-13-2007, 10:39 PM
very nice.. thanks alot.. Is it basically a line lock? Where can I buy a trans break?
Old 02-13-2007, 10:43 PM
GregWS6&z28's Avatar
for a 4L60E, only Rossler currently makes a trans brake
Old 02-13-2007, 10:44 PM
LS1Tech Sponsor
thats correct rossler only for the 4l60e
__________________
Call 888-744-6542
Old 02-13-2007, 10:46 PM
s346k's Avatar
a trans brake is NOT comparable to line lock.
a trans brake won't allow the tires to spin, as opposing gears (R and 1st) and engaged simultaneously..
whereas line lock simply locks the front tires (using the brakes, nothing to do with the transmission) and allows the back tires to spin freely, mostly for burnouts. my experience with line lock is that it's good for burnouts, bad for the start line...a car on slicks will push the front tires if only line lock is used to hold the car at the beams.
Old 02-13-2007, 10:47 PM
would the slp line lock do the same thing basically.
Old 02-13-2007, 11:27 PM
LS1Tech Sponsor
As he said line lock is not the same
__________________
Call 888-744-6542
Old 02-14-2007, 12:43 AM
SuperZ's Avatar
NO.Its no way like a line lock.I line lock would be the same as having your foot on the break stalling it up just like you already do.....
