Tranny builders??
Then clutches aren't your problem.... you have a pressure problem, bind up problem or leak in the circuit. chec your pressure with a gauge, check your vb for being flat, check the cases for cracks. ummm take your input drum and try to move the input shaft. a common problem is that they loose their press fit on your year. if that happens the shaft is just leaking oil and the 3/4 feed hole is blocked partially.
LS1Tech Sponsor
agreeded most likley the clutch set typ i not the issue though I prefer upgrades such a the zpack or blue plates, But I have seen even the stock clutch sets hold some decent hp for quite some time , I would as menetioned above check everything , Also of note what if any shift kit and servo are your using ?
__________________
