94 4l60e into a 93 Z28?
What will I need to do to make my 94 trans work in my 93 Z28? I have 2 camaros, the 93 has a bad trans. The 94 car is heavily built, and I would like to take the trans out of it and put it in the 93, and then put a performabuilt in the 94. The 94 trans is converted to be vacuum modulated already. Will this work in the 93? Not sure if the wiring is the same. Thanks, Nick.
Originally Posted by jay_lt4
wrong,,, a 93 z28 never had a 4l60e, it was a plain 4l60 with a tv cable(just like a 700r4 trans),, the 94 trans will not work in a 93 z28
http://en.wikipedia.org/wiki/GM_4L60-E_transmission
Any reasonable way to convert the 94 to work in the 93, or should I just rebuild hers? Thanks for the info.
or just look at the throttle body and see if there is a tv cable for the trans
if it is the 4l60(700r4) it will have 3 cables at the throttle body
gas cable, cruise control cable, trans tv cable
