Anyone who owns a TCI converter...
Old 02-19-2007, 06:49 PM
Matts94Z28's Avatar
Default Anyone who owns a TCI converter...
Do any of you guys have bad vibrations around 4k rpm? This is my second TCI converter in the car (Breakaway 2400 and a SSF3500) and they have both had the same issue!! It's a bit ridiculous in my opinion. I have swapped it out with the stocker and the vibration is not there. They claim their converters are tripple tested, but im on number 2 with the same problem!!
Old 02-19-2007, 09:33 PM
Pontiacerator
RevGTO's Avatar
Nope. If anything, vibrations lessened after my TCI went in.
Old 02-20-2007, 06:25 AM
Matts94Z28's Avatar
i guess i have bad luck then.
Old 02-20-2007, 08:48 AM
smoke20's Avatar
my tci converter is going out - getting converter shudder at 40-45 mph - converter wont go into lock up anymore. has been in car about 18 mo , getting ready to replace trans and buy a real converter!!!
Old 02-20-2007, 09:21 AM
mach2004's Avatar
Mine went out after 2 months of mainly daily driving. Mine also shuddered at about 45 mph also. I ordered a Yank Friday to replace it. I won't put another TCI product in my car.
Old 02-20-2007, 11:16 AM
Bill Bowling's Avatar
My TCI SSF 3500 works great in my D/D for over two years.
Bill
Old 02-20-2007, 02:06 PM
Matts94Z28's Avatar
I have heard that the older TCI converters are better for some reason. I dont know what the heck the deal is with these things. My last one stopped locking up after about 9 months of use and always had a bad vibration. Now this one has a vibration and i wonder if im going to have the same lock up problem as the last one in coming months...
Old 02-20-2007, 08:47 PM
Pontiacerator
RevGTO's Avatar
Same here with my SF3000.
Old 02-21-2007, 01:27 PM
Retired Street Racer
Matt D's Avatar
TCI ME 4500 here and no vibrations. It will go in/out of lockup once or twice when it is cold out (below 30*) but other than that, no problems.
Old 02-21-2007, 06:28 PM
dnkynrbk's Avatar
notice a shuddder the other day on mine too at 50 mph this is crap its only 2 months old
Old 02-21-2007, 06:47 PM
Cop Car's Avatar
check your flexplate, it might be broken
Old 02-21-2007, 07:05 PM
FANCHERFAST's Avatar
3800 been in the car for 2 years now with no problems at all.
Old 02-21-2007, 07:52 PM
Matts94Z28's Avatar
Trust me i have...I have checked everything from the flexplate to the u-joints. Its in the converter. I guess im going to give them a call and see what they say. Time to save for a yank or vig..
Old 02-21-2007, 09:19 PM
Outlaw LS1's Avatar
I've been daily driving for four months on my TCI converter and the shudder only seems to happen when the converter is locked up, or lack of it. So when i go into overdrive, at either 45mph or 65(highway), it always vibrates and feels like im running over the reflectors on the road. The problem seems to be getting worse and i started a thread about it before reading this one.
Old 02-21-2007, 11:15 PM
Moderator
jimmyblue's Avatar
My old TCI SF3000 was dead smooth, which I only noticed
after swapping to the present one. TCI does claim (or did)
to spin balance their converters. I wonder if it's true.
Lockup is not the TCI 10" converters' strong suit. You ought
to see about firming up the commanded lockup pressure if
you're able, it might let it last a while longer.
Old 02-22-2007, 06:50 AM
darrensls1's Avatar
Mine works just fine. The sad thing is that TCI used to have one of the best reputations around here. Kevin Winstead @ TCI used to post here a lot back in the day and was always really helpful. I never see him post here anymore though. Everything I have read the last year or so makes me never want to put another TCI converter in my car.
I'm considering myself luckly at this point and when the time comes for a new converter I think I'll be giving Yank a call. Sorry to hear about your converter issues and good luck.
Old 02-22-2007, 07:30 AM
omcar's Avatar
get a yank or Vigilante..the rest are not as good.
Old 02-22-2007, 09:18 AM
JS
JS's Avatar
TCI Part # 242937 SSF3200 works flawlessly in my GTO...
Its a custom,cross between a SF and a SSF w/better LU clutch and Billet cover..
Old 02-23-2007, 11:24 AM
Joel_SS's Avatar
Beware there is a known issue with the hubs that they use for the converters with the billet cover. They have taken out my transmission and one other that we know of. TCI confirmed the heat treat was bad on the hub making it brittle..
https://ls1tech.com/forums/showthrea...hlight=carnage
Old 02-23-2007, 05:23 PM
slowmofo's Avatar
My TCI Converter just took out my FTP Tranny..Im done with them..
